Assembly Manual Query
add1ct3dd
Post by add1ct3dd »
Hey guys,
Reading 2nd edition manual, but shouldnt make any difference.
I have the alternate style stepper motor connectors, which means no latch - anyway, the first picture on page 194 shows the wires in this order:
Yellow, Blue, Red, Green.
However Fig 16-35 lower down shows it as this:
Red, Green, Yellow, Blue.
I have the alternative, but wondered which way the pins are meant to go in?
Do I keep the wires alternated (power and signal) aka the backwards connector and run Blue, Yellow, Green Red? Or do I have to take the pins out and redo them? to match Yellow, Blue, Red, Green ?
Cheers!
Matt
guanu
SeeMeCNC Staff
Re: Assembly Manual Query
Post by guanu »
if you are looking at the rambo in the orientation of fig 16-35, the smooth side of the plug should be on top, meaining the wires going from left to right would be blue, yellow, green, red, you shoudlnt have to change any pins or mess with the plug in any way
Guanu
add1ct3dd
Post by add1ct3dd »
Thank you :)
Now to wire the rest of it up!
Sadly waiting for my RTV to dry, but doing everything else I can in the meantime, so will be 95% complete by tomorrow then just adding hotend/bed :).
Return to “Rostock MAX v2”
