support material?
jram
support material?
Post by jram »
Hi all,quick noobie question. I just printed out a small rc helicopter canopy from thing averse , I printed this on a Stratasys dimension printer, the canopy needed to be printed very thin and I noticed that that it printed brown support material around the white (canopy) material. This support material peeled off pretty easily with a little bending and twisting. How does the delta Max v2 deal with this as it only has one roll of filament on at a time? Does it print the support material in a sparse pattern so it can be cut away? I'm purchasing a Delta Max v2 soon and this is something I was wondering while watching my canopy print.I'm just beginning to learn about the 3d printing process after learning Form z and Rhino modeling for design/spec work, so any help is appreciated
Re: support material?
Yes it does print the support material in a sparse pattern so it can be cut away.
The slicer determines support, if you have support turned on.
jram
Post by jram »
Eaglezsoar wrote:Yes it does print the support material in a sparse pattern so it can be cut away.
Great! thanks for the help.
Return to “Rostock MAX v2”
