I am trying to finish up my Max. I downloaded the part layer fan zip file but when I go to open it, zip says its an invalid file. Where can I get this file from instead? I have downloaded other layer fans, but the mounting tabs are too far apart.
Thanks. Mike
part fan
Re: part fan
here's the stl of my latest revision
Guanu
Guanu
- NEW3-Guanu-Blower-Fan-Holder-Shroud.STL
- (87.39 KiB) Downloaded 344 times
Re: part fan
Thank you. I will print out this tonight.
Re: part fan
I encountered the same problem where the file was just a random string of alphanumeric gibberish. I just renamed the part to fan_shroud.stl manually and it worked fine from there
Judging by comments on the download page this has happened to others.
Maybe SeeMeCNC or whoever manages the download page can re-upload the file.
Re: part fan
Are you using a mac or do you have file extensions turned off? Seems like your OS is forgetting that it's an .stl for some reason...
Re: part fan
This part printed out great for me. Just what I needed. Thanks again. Mikeguanu wrote:here's the stl of my latest revision
Guanu
Re: part fan
glad to hear it!
Guanu
Guanu
Re: part fan
Thanks!guanu wrote:here's the stl of my latest revision
Guanu
I was about to draw my own. Printed and installed it last night.
Trying it now and it's helping quite a bit with the stringing.
Orion Delta Printer
3 Axis CNC router + rotary axis
Craftex B2229 Lathe/Mill combo
Re: part fan
Naw, I had the same problem with Windows. Windows just calls it a "file" and it doesn't have an extension - it's just a string of alphanumeric characters that the computer can't recognise.McSlappy wrote:Are you using a mac or do you have file extensions turned off? Seems like your OS is forgetting that it's an .stl for some reason...
Editting the name to "xxxx.stl" works in fixing the problem.
