error/difference between x and y axis in delta 3d printer
t_man
Post by t_man »
Hello friends
I have a problem on my delta 3d printer
Between x and y axis when im printing for example a cube 10 mm or 20 mm (print on repetier)
One corner can be 19.8 mm and the other corner can be
19.3 mm...
So every shap i print is not symmetrical.
In about 50 micron difference
I try to play with the diagonal radius but it change both x and y dimensions and not only one of them.
So what can i do to solve this problem ?
Thank you all...
teoman
Re: error/difference between x and y axis in delta 3d printe
Post by teoman »
That is a 500 micron difference.
teoman
Post by teoman »
Check the thread on adjusting the tower angles in the software.
Return to “The Build Zone”
