Hello friends
I have a problem on my delta 3d printer
Between x and y axis when im printing for example a cube 10 mm or 20 mm (print on repetier)
One corner can be 19.8 mm and the other corner can be
19.3 mm...
So every shap i print is not symmetrical.
In about 0.5 mm micron difference
I try to play with the diagonal radius but it change both x and y dimensions and not only one of them.
So what can i do to solve this problem ?
Thank you all...
error/difference between x and y axis in delta 3d printer
Re: error/difference between x and y axis in delta 3d printe
In addition:
First of all I stretched the belt - and it did not solve the problem.
I downloaded the hotend to 0,0,0 and measured distances to each tower.
With a ruler the distances were relatively equal.
But I printed isosceles triangle (square 15 mm ) and measured the height side of it (as the distance from the tower. )
The picture from top :
[img]https://lh4.googleusercontent.com/-uNGk ... ringle.png[/img]
I found only point tower Y is smaller than X and Z.
What to do? How to solve it? Maybe change the stepper mm Y axis only solve it?
If so how can i change it?
