JohnStack wrote:
As per PartsDaddy (Steve), someone in this forum is putting together a list of required items to do the upgrade. SeeMeCNC has the parts ready to go.
Yep, the parts list exists. I made it.
https://drive.google.com/file/d/0Bxa2nW ... sp=sharing
Keep in mind that this isn't the "official" document, it's just one bonehead's experience.
A few other notes:
First, I had many of the needed parts on hand. Depending on when you bought your kit, you may have some of these goodies left over too. The list assumes that you only have an assembled V1 - extra parts didn't count for my list because quantities have changed over the year and people like us tend to use extra hardware for other projects.
Second, there are multiple versions of the V1. Running changes are the name of the game, and if you bought the original crowdfunded machine, it's different in several small ways than the latest V1.
Third, you have to use the EZStruder on the new kit. If you don't have one already, you'll have to buy one. Which means that you'll need to run extra wires up top (which means you need the wires)... There are a few details like that, that I suspect may require a little bit of a "go get it yourself" situation
It's hard to make one kit that will have everything that everybody needs without paying for extras that others don't.
If you can't wait any longer, buy the wood (the part number on the website is the V2 wood, right Guanu?) and spend a couple bucks at the hardware store double-checking the list for the good of the community.
