I don't use it, too messy. I use hairspray(can be messy with over spray) this is what I use. http://www.amazon.com/Suave-Extreme-Hol ... B002I7I3AM
The arms on the Rostock Max is 269mm from the center of the holes at each end.AndThenSome09 wrote:Also http://www.tridprinting.com/Mechanical- ... -Screw-Kit sells pre assembled rods too. I think the closest they have to stock length is 250mm. Stock is 260mm I believe, correct me if I'm wrong guys.
