Edit/Update : Forgive my images I will clean them up and may add more after I am printing!
You are running stock u-joints and the newer SeeMe stock arms, correct? If you have side to side play at the ujoints, I would try some elastics near the joints top and bottom. This is how Trick Laser CF arms deal with any lash at the joint. http://tricklaser.com/images/1369294770 ... 56345.jpeg And these arms works fantastic!Prozac wrote:Well, back at it this morning. Working on the carriage u-joint mounts , im not having to sand anything of them , but there is side play , very little and seems equal on all 3. Is this okay ? " but has no side-to-side play." <--- I have side to side , best way to shim?
heres an updated picture.
[img]http://img.photobucket.com/albums/v129/ProZaC333/IMAG0124_zpsvycud0cd.jpg[/img]
