Hi,
I have been noticing a bit of build up on the extruder drive wheel. I think it is caused by the drag of the spool when printing at high speeds. I had a piece of 1/2" all thread in my shop and it fit perfectly in the stock brackets on the top. I printed these bushing to fit the SeeMe ABS rolls. They fit great and spin super easy. I also made this one for the PLA rolls because I just noticed they were different. I have not tried the PLA mount yet but do not expect any issues.
I am not sure what others are doing but the stock arm for the rolls to slide on was the first thing that I thought needed improvement.
Ryan
SPOOL MOUNT
- Plasticator
SPOOL MOUNT
- SPOOL BUSHING PLA.STL
- (28.6 KiB) Downloaded 262 times
- SPOOL BUSHING 2.STL
- (93.83 KiB) Downloaded 243 times
- SPOOL BUSHING 1.STL
- (94.22 KiB) Downloaded 245 times
Re: SPOOL MOUNT
Thanks for the idea and the STL files.
- Plasticator
Re: SPOOL MOUNT
FYI printing faster now with no build up (slippage on the extruder pulley). Extruder motor is also noticeably cooler. I am sure others probably already have done similar things but it is a simple thing that helps.
