I have 2 E3D hotends, I tried probably 10 different rolls of PLA, and I could not reliably print any of them, they would both exhibit basically the same issue, filament would stop extruding then if you were lucky it would dump the filament that stalled leaving a void followed by too much extrusion.626Pilot wrote:I've had good luck printing PLA with my E3D hot end, even with a 0.25mm nozzle. What cooling solution are you using?Polygonhell wrote: I use an E3d for everything except PLA, where it's a pain in the ass and I use a JHead.
There is a piece on my blog about my experience, including several examples.
I know there are many people claiming to print PLA reliably with them, I personally have not successfully done so, I have a JHead, it prints PLA perfectly, so I use that.
