This is a derivative of a derivative on thingiverse. You will need OpenSCAD installed if you want to change any of the dimensions.
Essentially this mount has 4 mounting holes and a slot to slide in the circuit board. All aspects of the design are configurable, I even build one for the EasyDriver.
http://www.thingiverse.com/thing:10115
I've attached my OPENSCAD file modified for the Velleman board and the exported stl file to print.
Mount for the Velleman MK138 boards
- Chris Muncy
- velleman mount.JPG (17.07 KiB) Viewed 3863 times
- Velleman temp controller.stl
- (62.99 KiB) Downloaded 316 times
- Velleman temp controller.scad
- (4.58 KiB) Downloaded 319 times
Chris Muncy
H-1 #5
H-1 #5
Re: Mount for the Velleman MK138 boards
Prints pretty good. I didn't have Slic3r set well enough to fill in the walls, but it will still function fine. No need for brute strength in this part.
Thanks for the file.
Printed on a Prusa, BTW.
Lee
