I'm pretty sure that's four washers per tri-support, not four washers per idler. The washers go next to the screw head and next to the nut, as they spread the load on the melamine.m4r1n5 wrote:On page 20 of the new manual the idler assy needs 4 washers. Are the washers to on either side of the idler assy? My screw only goes halfway thru the locknut with 4 washers...
Right!m4r1n5 wrote:Page 51, to make sore, does not need to worry which wire goes where concerning the stop switches. black can go on either ends.
Correct. Remove the excess solder and make sure the adjacent pc board pads do not touch each other with solder. Also make sure you get a good connection between the pin sticking through and the pad.m4r1n5 wrote:QUESTION...when soldering on the LCD board area, is it important that the solders do not touch other pins, or is it ok? I'm not good at this and some of my pins are connected through the solder
Pages 100 and 101 tell you to insert the thermistor into the hole and place RTV Silicone around it. When the Silicone dries you are supposed to solder the leads from the thermistor to the hotbed.m4r1n5 wrote:I didn't find a Hobbed gear in my inventory so I had to skip that and move on until I call up and get one sent.
I'm getting ready to install the hot end, might do some tomorrow. Between work and kids, I don't get much sleep to begin with. So far though its been fun watching this thing go up.
QUESTION... The thermistor in the center of the Onyx bed. Is that supposed to just hang there unattached to anything? I read the manual (pge 100 & 101) and found no other instructions after the kapton tape suggestion. Is it just supposed to hang there?
Ouch.. I'd be very surprised if that board still works. It looks like you cut a bunch of traces on the circuit board when you tried to undo your solder bridges.m4r1n5 wrote:, so I had to take a blade to it. SAD, I know, but the only way I knew how.
[img]http://i1326.photobucket.com/albums/u65 ... 6896f1.jpg[/img]
My bad, read it again and saw the "solder to the pads" in there. I guess thats what the pink arrows were pointing to and not the wires. All good, just take me another 30 min to fix up.Two things could be wrong here, you are reading but not understanding or you have the wrong version of the manual. On page 101 at the top of the page it should say The Rostock MAX Assembly Guide, 2
nd Edition. If yours does not say second edition on it then download the latest one at http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf.
Make sure you read and UNDERSTAND what you are reading. The complete instructions on how to connect the thermistor to the hotbed are on pages 100-101 that's why I don't understand how you can say there are no other instructions
after the Kapton tape suggestion. Make sure you have revision 2 of the manual and make sure you download the latest Abobe Reader. You are missing something but not to worry we will figure it out. Let me know when you can read the
rest of the pages 100 and 101, I want to make sure your reader is working and you have the correct manual. Get back to me and let me know. It is very important that you do not miss steps.
You should have either a) used solder braid, b) used a solder sucker/vacuum tool or c) let someone with more experience soldering fix it for you.
The yellow soldering iron probably would have worked fine if you got a smaller tip for it.
Would it be safe to wrap that area of the hotend in kapton tape as well as having the RTV on there?ApacheXMD wrote:Make sure you secure the thermistor VERY WELL. You do not want it to pop out during a print or else very very very bad things will happen, i.e. melted hot end and potential for fire.
