I would like to try Cura, Does anyone have a configuration file for a stock Rostock to share?
Any tips or advice would be nice.
Sounds like to would be better for a bowden extruder with the retraction.....
Bill
Anyone have a Cura configuration file?
- truenorthtrader
Re: Anyone have a Cura configuration file?
Hey Bill I'm using Cura for some prints, noticed some things don't print as well as Slicer but most others will.
Here are screenshots of the majority of settings.
I have the original square bed so those settings would be different if you have the Onyx bed
Hope it helps!
cheers
Hope it helps!
cheers
thank you so much,
Is that the temp for pla or abs?
Bill
Bill
I tried it and it shows the part on the edge of the table? How do I move it to the center?
Bill
Bill
When you download/install Cura, did you click on the option to have the center of the bed at 0,0,0?
Thanks for posting.
Did you use Cura for the host?
I clanged it to 0 and that worked, thanks!
My last issue is that when the print begins, it starts with a retraction that starves the nozzle for much of the first layer....
Bill
Bill
here is the cura profile from seemecnc, this was taken from the rosoft link.
this is my current profile i've been testing, use at your own risk
