Auto calibration g29 sometimes crashing into bed
raptor
Post by raptor »
Hi All,
i just upgraded my rostock v2 to have an accelerometer board and i have noticed that if i run G29 to do the bed calibration from the terminal window it works fine, but then if i put it in the start section of my gcode and hit print, it heats up and starts and then crashes into the bed when doing the x tower (not just a tap but it overshoots and you get a grinding noise).
Any ideas what is going on?
Full setup:
Rambo board
firmware 92.2 (hotend selected at type 3 he280 w/accelerometer)
e3d hot end using this mount https://www.thingiverse.com/thing:2098268
seemecnc acclelerometer board rev 6
ballcup arms and effector plate
original cheapskates with ball end adapters
DIY berd air
slicer is S3d or matter control
i have also tried with astro print and it does the same thing
pouncingiguana
Re: Auto calibration g29 sometimes crashing into bed
Post by pouncingiguana »
Depends on where in your starting gcode it is. You can't run either of the heaters when you're using the probe as the pwm signals interfere with it a lot. I'm guessing at least one of the heaters is active when you're probing. Can you post your starting gcode?
raptor
Post by raptor »
Ah that's probably it then,
i was just doing a G28 and a G29 to start the print but i think that the heaters were running. i'll do some tuning.
thanks
