Issue with printer not printing on bed
Bismarck83
Post by Bismarck83 »
I have an Orion Delta. worked wonders till the old mobo fried. After getting a knew one (months later) I kinda forgot how to do a lot of stuff, I am hoping you guys can help me out. below is my eeprom settings if it helps. I zeroed in the tip to be flush with the bed manually, saved settings exported it to EEProm , everything looks good but when it begins to print it hovers a few ..maybe 1/4 of an inch (guessing) and starts to print off the board in the air., I checked the zeros again and everything seems fine.
I am using a Orion delta printer
Using Matter hackers slicer
hope you guys can help
THANKS!
eeprom_settings.ini
(2.06 KiB) Downloaded 414 times
