Where do you get the lazer arm upgrade
bplemmons
Post by bplemmons »
I've seen pictures on the build zone of metal arm upgrades that are called laser arms and there is a china version...
Anyone have links?
Bill
cambo3d
Re: Where do you get the lazer arm upgrade
Post by cambo3d »
tricklaser.com, light weight version
or china made metal version off of ebay
you have to specifically ask for 269mm or you will get the 250mm arms.
I haven't tested the tricklaser arms yet but they should be the mail shortly.
The china made all metal one is working out great for me, theres no slop or play in the shafts. but you do have to get your own hardware to mount them. The ball ends are snug but not tight, was able to free them a little more by throwing some grease on them.
http://forum.seemecnc.com/viewtopic.php ... 280#p10225
bplemmons
Post by bplemmons »
What key words do I use to find the ones on ebay?
Bill
cambo3d
Post by cambo3d »
search rostock
http://www.ebay.com/itm/Reprap-Rostock- ... 4ac2df4053
took about a week from china
Seems like I am always thanking you, it's probably because you are always helping me.
I did do a search for Rostock and found the arms, I needed for you to verify that he was the correct seller.
Thanks again :)
cambo3d wrote:tricklaser.com, light weight version
I saw the tricklaser arms in person tonight. They're awesome, I definitely want a set!
RSMaxwell
Post by RSMaxwell »
I got a set of these. Seeing that you are a much handier guy than I, would you share what you used for mounting hardware?
*** NEVERMIND. I FOUND IT IN YOUR BUILD LOG. ***
cambo3d
Post by cambo3d »
yes its in my build log http://forum.seemecnc.com/viewtopic.php ... 300#p11004
I thought i posted the hardware i used but can't seem to find the post. i used 3mm x 30mm machine screws and and matching lock nuts.
edit found it: http://forum.seemecnc.com/viewtopic.php ... &start=270
Return to “Rostock MAX”
