high temp jet kit
Twac1
high temp jet kit
Post by Twac1 »
so I have the kit, but how do I raise the high limit on the hot end from 240 to 280? and will the thermal switch kill before?
tjschweizer
Re: high temp jet kit
Post by tjschweizer »
I don't know about the thermal switch, but the max temp limit is in the Configuration.h file in the firmware. I'm assuming you are using the Rostock Max V3? Are you using OctoPi? The firmware looks like it defaults to having a Max Extruder Temp of 290°C. It may also be in the EEPROM, not sure.
