Is it possible to use the latest seemecnc firmware with a simple switch on z_min as z-probe instead of an accelerometer? If so, how should it be setup in Configuration.h?
Thanks for any insights anyone may have!
Auto Calibration with switch instead of accelerometer?
Re: Auto Calibration with switch instead of accelerometer?
Short answer, no.
Thanks. I thought that might be the case from looking at a bit of the code. Just wanted to make sure I wasn't looking in the wrong spot or missing something obvious.
